M113 V8 Kompressor Platform Technical discussion relating to models sharing the M113 V8 5.5L Kompressor. Including SL55 AMG, CL55 AMG, S55 AMG, E55 AMG, CLS55 AMG, G55 AMG, SLR (M155).
How to change the ic pump on an S55
Old Jan 9, 2011 | 07:37 AM
cerruti's Avatar
S55 AMG 2003
Hi. Been searching for ages on some instructions on how to change the ic pump on my S55, found some stuff for other models but nothing for mine.
Does any one know where i can find some details on how to do it myself.
Thanks in advance.
Old Jan 9, 2011 | 08:50 AM
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
What's your model year?
Old Jan 9, 2011 | 08:58 AM
cerruti's Avatar
S55 AMG 2003
Hi It's a 2003 model
Old Mar 23, 2011 | 05:21 PM
Viet_Amg408's Avatar
Pinto
its easy...remove lower front bumper splash guard..you shold see the pump lower right corner..
10mm two bolts.. and clamps to remove the hose...
if you bought oem one..it should direct connection to the wires and vacuum hose..
if you have aftermarket..the vaccum hose can leave out.. and splice the two wires together..
