Vibration at 2500 RPM
Forward engine mounts have been replaced (the LH one was completely shot and needed to be replaced anyway). However, vibration remains. Removing the belt for the blower lessens the vibration slightly, though it is still there. (This test was only performed in Park.) As a sidebar, we did discover that the idler pulley bearing for the blower belt is very wobbly and needs replacement.
When my repair shop had another '05 S55 in for repairs at the same time, the exact same problem was on that car as well, although the car’s owner is not complaining about the vibration and has owned his car since new. Nevertheless, having another car with the exact same problem was a bit of a shocker.
Since I've had the car only about a month or so I’m not sure if this is the nature of the beast or something failing. I’ve owned an S-class (W140, non-AMG) model before and it was smooth as silk through the entire RPM range. Just wondering if anyone has experienced this problem before, or if this is normal (though I seriously doubt it). Any and all comments are welcome, and thanks in advance.
Cheers,
Jeff B.
Cheers,
Jeff
Cheers,
Jeff
BTW, the engine continues to run very smooth through the RPM range, so I'm convinced the transmission mount was the primary culprit. Now to get that idler pulley assembly rebuilt with new bearings - but that'll be another thread.Cheers,
Jeff
