M113 V8 Kompressor Platform Technical discussion relating to models sharing the M113 V8 5.5L Kompressor. Including SL55 AMG, CL55 AMG, S55 AMG, E55 AMG, CLS55 AMG, G55 AMG, SLR (M155).
Ml55 not revving
Old Mar 22, 2013 | 04:24 PM
D5mo_h's Avatar
Ml55 amg
Ml55 not revving
Hi all I'm new here my names damo this is my second ml55 I'm having a bit of bother tho. It starts fine and drives great under normal driving but as soon as you try to go over 3500-4000rpm it goes limp I've changed air flow but no joy
Any help would be great thanks
Old Mar 24, 2013 | 09:03 AM
AMGenema's Avatar
2003 SL55 AMG
Hi Damo, I'm a newbie too. I have a 2000 ML55 AMG and I know it revs pretty well. I've had it to 6700 RPM under full throttle. If the air side is fine It could be the fuel filter, you need both to run right. The MAF sensor may be to blame as well. If it's not sensing enough flow the computer will not send the signal to pulse the injectors properly. Just a couple of thoughts, it should be put on a diagnostic machine, you could spend a lot of money changing parts.
Old Mar 24, 2013 | 12:47 PM
D5mo_h's Avatar
Ml55 amg
Yeah defo it's been on it and condemned the air flow so changed it its going back on computer tomorrow see what it kicks up next I had one before and loved it so had to buy this one but depends what's up as my pockets are only so deep haha.
Old Mar 24, 2013 | 04:08 PM
AMGenema's Avatar
2003 SL55 AMG
I know the feeling, I did front lower ball joint, wheel bearings, front CV shaft, center driveshaft bearing, rotors and pads all around, window switches and tranny flush. That was from 80K to 110K miles, I think I should be fairly trouble free for a few miles now.
