'03 CL55 AMG Won't Start
Looking for advice on a "no start" issue with my CL55. Car has been running fine. Occasionally it has a rough idle, but very seldom. I get periodic malfunction messages, but they go away on re-start. This morning I got malfunction lights for ABS, BAS and ESP. I drove my son to school, stopped for gas on my way back home and turned the car off for about 20 minutes before leaving for work. When I tried to start it again, it turned over but wouldn't start. It showed the same three malfunction messages, but I don't think they have anything to do with the car not starting. I plugged my OBDII scanner in and found no codes in the computer. I read on line that a bad crank position sensor can cause this sort of thing, so I replaced it with a non-oem sensor from Advance. The car still won't start. If the crank sensor is bad, shouldn't there be a code in the computer for it? Any ideas?
