M113 V8 Kompressor Platform Technical discussion relating to models sharing the M113 V8 5.5L Kompressor. Including SL55 AMG, CL55 AMG, S55 AMG, E55 AMG, CLS55 AMG, G55 AMG, SLR (M155).
Power Trunk Operation Question?
Old 03-08-2017, 04:30 PM
FTLOMB's Avatar
2006 CL55 AMG
OK, just purchased 2006 CL55 AMG. The trunk works great, but I guess its pre- programmed to shut after about 30 seconds! I can't even vacuum in there, just enough time to get my hands out of way .
Anyone know how to reprogram to just stay up when opened?
Old 07-13-2019, 09:10 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
I am unaware of a setting or configuration that would do this. It doesn't sound like a function that Mercedes-Benz would even make configurable due to the potential injuries that it could result in. If you resist it closing, does it open back up?
A workaround would be to disconnect your battery while vacuuming in there, but again, this should not be a setting; it sounds like a malfunction that DAS would need to help diagnose.
pmercury (02-23-2020)
Old 02-23-2020, 06:00 AM
member
pmercury's Avatar
CL
yes this requires Xentry Das
I know how to program those settings if you need
Quick Reply: Power Trunk Operation Question?
