M156 V8 Platform Technical discussion relating to models sharing the M156 V8 6.2L engine. Including SL63 AMG, CL63 AMG, S63 AMG, E63 AMG, CLS63 AMG, C63 AMG, CLL63 AMG, ML63 AMG, R63 AMG.
Help diagnos A/C issue
Old Aug 7, 2019 | 12:55 PM
CanadianC63's Avatar
2008 C63 AMG
Help diagnos A/C issue. SOLVED!!!!
Hello,
I have been having issues with the air conditioning system on my 2008 C63 and am looking for some assistance in diagnosing the problem.
Up until a few weeks ago, the A/C would blow cold while cruising and when the weather wasn't too humid. Now it has stopped blowing cold all together.
I managed to get my hands on a pressure testing tool and the results were as follows:
A/C off: Low side 89psi, High side 115 psi
A/C on : Low side 88psi, High side 105psi.
I'm guessing it is either the compressor or the expansion valve stuck open.
Any A/C expert here that can chime in?
Thanks.
Old Aug 8, 2019 | 12:35 PM
2008 C63 AMG
Originally Posted by Plutoe
High side should be 210 psi you are either low of refrig or the compressor cant make pressure
Thanks. I tried to add refrigerant yesterday but the system would not take it, so I suspect the compressor isn't working.
I'll check the pressure switch first, and if I see power going to the compressor, then I guess I need a new compressor.
Old Aug 28, 2019 | 01:56 PM
2008 C63 AMG
Solved!!
It was the pressure switch. It also cured my fan running on high all the time.
