M156 V8 Platform Technical discussion relating to models sharing the M156 V8 6.2L engine. Including SL63 AMG, CL63 AMG, S63 AMG, E63 AMG, CLS63 AMG, C63 AMG, CLL63 AMG, ML63 AMG, R63 AMG.
Cannot connect to ESP/ABS module after factory update
Old Jul 11, 2020 | 12:42 PM
CanadianC63's Avatar
2008 C63 AMG
RESOLVED: Cannot connect to ESP/ABS module after factory update
Hello,
Ever since MB performed an update to the ESP/ABS module, they have not been able to connect again to the ESP/ABS module to diagnose "abs/esp inoperative", "cruise control inoperative", "run flat inoperative", speedometer not working.
Neither MB, nor my local MB tech using a snap-on diagnostic tool can connect to the module to diagnose the above issues.
Last year I replaced both rear tone rings and this year replaced the brake light switch, but I imagine replacing parts isn't going to help if the ESP module isn't connecting. If I reset module by disconnecting the battery, it works for a few miles then the lights come back on.
Help!
Thanks!
Old Jul 16, 2020 | 06:01 PM
2008 C63 AMG
This was the result of the latest scan.
Old Jul 17, 2020 | 10:19 AM
2008 C63 AMG
So I just tested both front abs wheel sensors using the ohm and volt tests and they both failed. I’m assuming that means both need to be replaced.
Old Jul 25, 2020 | 08:49 PM
2008 C63 AMG
Resolved!!
It was the accelerator pedal sensor after all! No more dash lights!
