Difference between 600 and 65 TB?
W220 S65 AMG
Do we know what the difference is between the TB on the 600s and the 65s?
I looked up the part numbers and the intake manifold is the same exact part number for both variants...
Reason I ask is because I have a TB for a M275E60 AMG motor laying around I would like to install it when I do the thermalnators..
One more thought, wasn't the 600 engine out BEFORE the 65. If this is the casae, again it would lean HEAVILY towards them sizing it for the 600 TB, with NO upgrade on the 65.
Okay Chris:
I was at my local MB dealer beating up on a SLK55
So I went to the parts department, where they love my by the way, ha, ha
The intake manifold for a S65 or S600 is the same part number, as you knew
The throttle body gasket for the S65 or S600 is the same
The throttle body part numbers are different.
However, if the gasket is the same, and the intake manifold is the same, one can easily dadoes that the bore MUST be the same. Sorry for the bad info, but the fact of the matter is, you will see NO GAIN from using a AMG S65 throttle body on an S600
Sorry
Sorry
