M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
ECU tune parameters
Old Dec 18, 2009 | 10:48 AM
Flight Test's Avatar
Buick T-Type, 70 cuda, S65 and a very FAST Truck!
ECU tune parameters
Does anyone know if the current S65 ECU tunes can disable or limit the traction control function? It would be nice when you disable the system by pushing the button it would kill the electronic nanny that is always present. I know we can always access dyno mode, but just hitting the button would sure be easier.
It looks like the current ECU tunes control: boost, timing, and fuel along with the speed limiter. What other parameters can be adjusted/tweaked?
Old Dec 19, 2009 | 05:52 AM
2003 S600's Avatar
2003 s600
It made traction control more intrusive in mine. I lost the pulsing of the brakes and throttle cut is much more now.
Old Feb 24, 2010 | 10:02 PM
Oxygen's Avatar
W220 S65 AMG
If you are looking to kick the ESP nanny out of your house, I would suggest Dyno Mode.
