V12TT coil pack's
My S65 blew the driver's side coil and I went with an OEM replacement... took about 50 minutes to install and all was great. I think the OEM coils last about 50K miles or so. Mine blew it at around 22K miles. Not sure why...
I'd like to replace all the spark plugs soon.
how much money im not selling my parts i told you i need them fix..... so i got pissed and told them just send it back, so his responce was "ok i will. call tomorrow for tracking number"these guys suck big time!!!!!!! i wish i saw there google and yelp review before i sent my parts
When I had you all upgrade my ECU/TCU we discussed that a coil might follow soon, I had already had the drivers side replaced, well last night the passenger side started acting up. I'm heading to Hawaii next weekend so I'll deal with it when I get back.....
I used NGK's, same numbers as the stock MB plugs.....IFR6Q-G
Driver side was harder than passenger side due to fuel line etc., but neither was insurmountable with a little patience. I also used the OEM replacement plugs
Very educational info about octane and the packs. I will try some high octane fuel in the Spring for a little fun.
What grade would we need to use to tell a difference ?
Also how fast does it adjust to the higher grade fuel ?
something like a month or so until failed again
I've got a passenger bank unit you could have for shipping cost, the last spark plug 'boot is missing due to my hamfistedness and it had failed internally prior to my hamfistedness.
Interesting data on the sophistication of these units - helps explain the astronomical sums they command 8-/. Thanks for sharing that detail...
I think the hard part is to confirm they are working well at higher voltage simulating wide open throttle..
For now Im wondering if there is anything can be tested out with a multimeter.
I'm Putting on extra dielectric grease in and around those red insulators and some in coil holes..
I THINK I got a batch of bad gas. The car started going in and out of the normal high performance mode and ran rough at times. A couple of times it stalled. I filled up with 1/3 tank of Premium Ultra Sunoco and the shaking stopped and car is drivable. NO performance though. I PULLED the driver's side plug on the coil pack after getting codes for 7,8,9,10,11,12 misfiring.
The car ran (!) and idled smoothly on just the right bank!
I saw a post about "how long does it take" to see results from X high octane fuel, but no answer... my question being, will crappy gas cause a pack / side to not function? The car seems to be running better and better and I am ready to fill it with X Prem Sunoco.
Is it possible that the gas was SO bad the coil pack would not respond to it?
Will O2 sensors (2 per bank?) shut down a coil pack?
Is the Thruway / Ecconomy mode the same (shutting down 1 bank)?
Are the Coil Packs FUSED?
I VERY much appreciate your answers. Thanks. Tom
