Cooling down the V12TT
Lowering IATs does not really make horsepower. What it does as Formula says is allow you to keep the horsepower you're making and not heat soak, which is when the ECU pulls timing and you lose power.
I have a lot of track time with an Audi turbo using Aquamist. While some things do not translate directly, I was running 28psi of boost (correct, almost 2BAR) for hundreds of laps one after the other at Watkins Glen and other places.
The Aquamist system I used (and there are lots of choices) pulled 100 degrees fahrenheit out of the IAT. It was better than using 100 octane race gas, which has a higher ignition temp and is therefore less susceptible to detonation, which is what lowering IATs accomplishes. When the car detonates (fuel mixture pre-ignites), the ECU immediately pulls timing and boost to compensate, so you lose power.
With straight-from-KMart blue washer fluid at 99 cents a gallon (blue washer fluid is half methanol at 114 octane and half water which is the best liquid to remove heat), the difference was incredible. The few times the tank ran dry and I lost the water injection, it was like someone pulled 75HP out of the car. Plus you can tune for WI, and advance timing knowing you do not have the same heat/pre-ignition issues to deal with. That's why some companies will give you tunes for 91, 93, 94, and/or 100 octane. They can increase boost and advance timing more at the higher octanes. Blue washer fluid is perfect for that if injected in an atomized mist about 6 inches forward of the intake manifold.
It's cheap, engineering is not complex, it works, and it's not hard to remove if needed. I lkoved it when I ran with it, huge difference, no heat soak, and cheap to buy/install/run.
Bruce
Bruce great post lots of info, not many Mercedes guys going with these systems that I have seen, I wonder why ?
Being that you can't get below ambient, then your goal is to keep IAT as close to ambient as possible. That won't make you more power...but it will help you retain your power. Dyno your car while it's cold; then go drive it around, make a couple full throttle runs, and then go dyno it again...you'll see what I mean.
As in - you know how your car pulls really hard at 40*? Well, you're goal is to keep it performing like that even if you're in the throttle for a sustained period.
The turbos are loud with this set up as well as the bov's. not ricey, but sound good. As far as cooling i put in a larger front heat exchanger with the meziere pump and that made a noticable gain.
How much HP / TQ does the added 1.6 boost make ?
What HE did you got with, what size where id you get it ?
As far as the HE, I fabbed it up my self. I got the core cheap. I believe it was for either a 03 cobra or a lightning pick up. I dont have the exact measurements but it is big, actually slightly too big. I had to trim some brackets and dimple the top of the core to clear a abc line.
02cl55amg
The exhaust is all stock except for the rear muffler delete. I was going to do down pipes with 100 cel cats however speedriven is working on something very interesting and I am holding off on any more mods until this prototype setup is ready for sale. Were talking BIG power numbers!
I would be careful not running filters! I have seen two cars ware the stock filter housings werent sitting on the turbos properly, they sucked in dirt and destroyed the barrings and impellers in the turbos. I'm not sure on the pn for the filters however I remember that they are for a aftermarket intake for Harley's. On k&n's web site they list the sizes of every filter and cfm they make on a list. just a pain to find what fits. usually motorcycle or snowmobile filters are the right size.
Never mind the missing grill, I'm in the middle of buffing the car but this gives you a idea of the size.
Bruce
Regarding the section i highlighted, did you actually confirm this claim via datalogs? Is this similar to "meth injection" a lot of guys use?
I can see this being effective at the roadrace track, the gains you claim are like nitrous but at all times! In the 1/4 this should also do wonders for mph and e/t. I can tell you from data logs no matter how cold it feels outside IAT's are up there half way down the track.
StockC43-with me and cars its Murphys Law. If it can happen it always happens to me LOL. Looks like more research is in store for me. By not tuning for it does one take the chance of running lean? Does its presence(or lack there of) affect AFR's?
freestylebiker-im with Formula id love to see the writeup in this thread.
https://mbworld.org/forums/cl55-amg-...p-upgrade.html
Here is a link to the discussion: http://twinturbo.net/nissan/300zx/fo...tion-fail.html
http://www.killerchiller.com/
http://www.youtube.com/watch?v=BR7kYFf_MaU
or
http://www.coloradospeed.com/index.p...ducts_id=20381
http://www.youtube.com/watch?feature...v=QQ9EbjSH_X8#!
The RX Super Chiller system is the most convieniant, effective, and easiest to use intake air charge cooling system available today.
The RX Super Chiller uses the cars AC system to chill the coolant used in water to air intercoolers to temps of 22-32* F on a continueous bases as long as the car is running and the AC compressor is on. The system only adds 7-9#'s additional weight on average and reduces the intake air temps on forced induction applications by 40-60* F allowing a densor more qxygen rich intake air charge for more aggressive tuning (avg 20-50 RWHP/RWTQ increase) with out the reacuuring costs of refilling CO2 tanks, or the hassel of ice chests and the melt water/added weight.
The installed sytem requires only 5-6oz's additional freon and each system has a "competition mode" that allows for the cabin AC to be disabled so there is no water dripping from the moisture removed from the cabin air. Track approved for both drag & road race. (for professional road racers we have an optional remote mount 12v compressor used just for the chiller system and allows continueous use at all rpm's)
The RX Super Chiller adds NO parasitic power loss as todays computer controlled systems the AC compressor disengages as soon as you go WOT (wide open throttle) so during your run down the strip the comp is off and their is enough residual cooling that by the time temps have risen 10-15* you are at the end of your run and the chiller kicks back on.
For street use the cabin AC works in conjuction with no noticeable reduction in the cabin AC's ability to keep you comfortable.
Available as complete add on system for most popular modern muscle cars and light trucks with custom systems for any forced induction application.
Although some of the W211 crew swear by it
I have mixed feeling regarding it, IMHO
Any other issues ?
Also, I have my reserve about its capacity, aka cooling off the large interior and the IC's at the same time.
Again, some of the W211 crew love it, so I may be just a worry wort
A key reason for that is that, although the mixture may lower the charge temp, it also replaces some of the charge air going in. In other words, it tends to richen the mixture. That won't help power unless you are already running lean.
Alanb
Where I did see gains was simply by adding 10% methanol to the fuel tank. This has the effect of both leaning the mixture and increasing the octane. In the UK, methonal is cheaper than petrol (gas) and so it's a great 'solution'.
Alanb
