M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Sneak Peak Heat Exchanger
Old Jul 29, 2012 | 11:08 AM
Benz-O-Rama's Avatar
The more data I see on V12TT cooling, the more I think meth is the way to go.
Old Jul 29, 2012 | 07:56 PM
Vabene7's Avatar
Garage Temporarily Empty
I absolutely agree..... Meth is the most cost effective option at maximizing your HP.
Old Jan 28, 2013 | 10:25 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Meth is fun but also if it fails its no fun
Old Apr 18, 2016 | 01:15 PM
HRHohio's Avatar
C230k, ML350, and CL600
Where to draw 12v power from in the CL600 engine bay?
Raising an old post, but I was curious about the 12V power source in the engine bay. Can you elaborate?
Thanks!
Originally Posted by shardul
1) Is this a custom made intercooler or a "standard" element made to fit?
Both the Primary and the secondary are custom made from new cores. The 600s only have the thin heat exchanger between the radiator and the front bumper, so we made a bigger one and also added a secondary unit in front bu the bumper support.
2) What signal/power do you use to trigger/drive (run) the Aux fan you mounted?
We used a switched 12v power source from the ECU box in the engine, bay. I can take pictures of the wire.
3) Would a small Aux fan (like one from a motorcycle) in front of the extra intercooler be an idea?
It would help a bit when the car is moving slowing or when you race you are in the staging lanes you can trun that fan on. TO be honest I dont think it will help that much.[/QUOTE]
