Refreshing the divertor valves on a M275
Price of the kit is 40 per side.
A fellow member Adam has been very helpful in guiding me. I may change out the spring on the divertor valve with an aftermarket 5 to 15 psi one.
Just picked up the kit.
As per WIS the passenger side one can be accessed from the top but the driver side one has to be replaced from the bottom.
The 600 and the 65 share the same part number.
Aaron
On one of them, the rubber diaphragm had split, so the valve must have been stuck closed.
I tried to get a new one from my MB dealer today, but was told they weren't available.
I've been searching everywhere; even tried translating and searching in German.
Can anyone help me source a pair of new divertor valve diaphragms?
Thanks, Nick
ON EPC pull you the turbo manifold diagram and select the divertor valve cover and I will include the above mentioned parts.
I've never been able to get EPC working on my SDS, so I pulled this from mbpartsworld.
Nick
Still struggling here. I took that picture back to my dealer, which he found on his system, but the item was greyed out, so not available in the UK.
I also called half-a-dozen leading turbo rebuilders and resellers in the UK, but none could sell (many didn't know what I was talking about at first).
The part number given by mbpartsworld is 2750960002. If I buy that, do you think I will get the diaphragm, piston and spring, as well as the cover?
Obviously, I'd like to be sure that P/N is for the assy, not just the cover.
Cheers, nick
Its funny, I've been speculating for a year that there's got to be an easy way to do motor mounts and other "engine out", jobs that I was almost looking for an excuse to try it for myself. Then this happened, and I didn't have much choice. As always with the V12TT, its been a learning experience, and apart from automatic transmissions, I'm not really afraid of anything anymore.
I have two new engine mounts and six ABC pipes also waiting to go in this weekend, and this is how I do it ....
Nick
