Intercooler Circuit Overflow Reservoir
This modification definitely bleeds the entire system but it takes time. It will take multiple heat cycles to expand the air in the intercooler system which gets pushed out through the wilwood reservoir. When the system cools back down it draws the liquid back in. I have been running this system for years now and every time I take off the intercooler radiator cap it is 100% full of coolant. Before adding the reservoir there was always a bit of air under the cap, I always fought with getting the system bled.
The newer v12tt cars have a very similar set up.
Best of luck to all.
Lol sorry I messed up with the original retrofit that does not and I use
https://mbworld.org/forums/m275-v12-...atibility.html
good info
A2792000185 Tank
A2790980891 pipe to tank
A2790980283 rubber hose
Ends up looking like this.
A2792000185 Tank
https://www.sfbenzparts.com/
all you mentioned is perfect
then in terms of cooling, start with the Weistec water/meth kit. you might skip the cooling after you see the result
just insane
Adding the new expansion tank for the low temp circuit won't make any difference in your temperatures, assuming you don't have air in your low temp (intercooler) circuit to begin with. It does nothing to change the way that system works. All it will do is keep the system from sucking in air. If that happens, you will soon find your low temp circuit partially empty, and your IAT will suffer because the intercoolers won't get enough water circulating. In a perfect world, this wouldn't be an issue -- the low temp circuit won't get hot enough for the coolant to expand and vent from the fill cap. Well, we don't always live in a perfect world, which Mercedes seems to have eventually figured out.
If you read on this forum enough about these cars, you will soon find out that the original design as you have in your car right now is flawed. The flaw is the lack of an expansion tank to allow water to expand to somewhere as it heats up during operation. The original design (again, as it sits in your car right now) does not allow for this and what happens instead is that the water expands and lifts the relief valve on the cap between the two intercoolers and escapes. Later as the system cools down, air replaces this coolant that escaped. This air, forms air pockets which prevent efficient and at times, even blocks proper circulation. This in turn, leads to heat soaking and high intake air charge temperatures which in turn, force the engine ecu to retard timing and add fuel in order to keep the engine from detonating.
This all means that original performance is reduced by not having this update. AMG introduced this update in 2014 when the engine was revised and re-named M279. My opinion is that this is a must do in order to make the car more reliable before one starts adding tunes and other mods. Unless you’re doing something completely mind-blowing like @pmercury , you’re more than likely stuck using the stock intercoolers so... do this mod/update and upgrade the circulation pump and you’ll be at a good starting point.
Good luck on your build and start reading through this forum!!! Knowledge is power....Horsepower!!!!
A quick one as I could not find details in the manual as to how much MB coolant to use in the interecooler circuit....., any idea in Litres ?
Also do I use the MB unmixed coolant for this, or 50/50 with filtered water ?
Regards,
Grant.
