M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
M279 Improvements Backward Compatibility
Rating: Thread Rating: 2 votes, 5.00 average.
Old May 19, 2016 | 03:54 PM
MooksM275's Avatar
W215 CL65
Was playing with EPC and wondered what changes were made to the newest 65 amg cars. I found something very interesting.
So, I had experience with backward compatibility for parts when I had my Z06. Chevrolet's improvements could, many times, be adapted to improve on the previous cars. For example, shocks that had better valving etc.
Well, I was curious about the changes that were made to the new W222 and W217 65 AMG, officially the m279 M60. Most of everything on EPC looks very very similar however there are two things that I see have been changed and wonder how they could work with our vehicles.
1. New Expansion Tank for Intercooler Circuit: There is the addition of a plastic, larger, overflow tank for the secondary charger cooling circuit (intercooler circuit). Part number is A2792000185.
2. New Designed Ignition Coil: Deletion of Voltage Transformer: Here, they have gotten rid of the expensive coil packs and replaced with what looks like individual coils that are daisy chained. You actually buy each coil individually, making future maintenance waayyyyyy less of a hassle (no more changing an entire coil pack) Also, there is no longer any Voltage transformer, they are using the Engine ECU only. Part Number for new designed ignition coil is: Right A2799060700 Left A2799060700. You can also buy the coil connectors that go down into the cylinder individually part number A2791590042. See pic of engine in the car and you will also notice that it is white/clear (allowing for easy fluid level spotting). It looks like they can be bought for around $160 each and there are 6 per side. The major cost would be switching, however, they are cheaper than the originals and later you wont have to change all the coils again.
With this change, the voltage transformer is gone and the space where it went is now filled with a bracket that houses all of the electronic vacuum switch over valves that are right now found on our left and right cylinder heads. See pic below.
With the expansion reservoir, I might buy one (looks like I can get for around $120) and let you guys know how it works out with pictures. It doesn't appear that it is self bleeding so that is a bit of a drag, however, it will allow us to monitor fluid level without opening system and allows for a greater capacity of fluid in the reservoir (a major problem with the original design). The mounting hols look to be in the same location as our small "reservoir" and looks like it should be plug and play. Ill keep you posted.
As to the ignition coils.....with the advent of the new speedriven ecu, I wonder whether this would be a direct fit and could be utilized with their system. Or whether you could somehow get the new ECU to work with our cars.
I am going to delve into more of the changes and see if there is anything else.
Popular Reply
Jul 7, 2016, 09:11 PM
MooksM275's Avatar
MooksM275
W215 CL65
Fit great
All is installed, Bled and working great. Fitment is fantastic. Easy to see water level, room for expansions when water heats and cools. Fits in standard location with same bolts as original water "tank".
Install was easy but required 1 modification. On our wiring harness cover, there is a single small ear that holds the original water crossover pipe (had a circular clip ring that bolted to it). Unfortunately, that ear is in the way of where the new tank enters the new pipe. So a quick cut and the ear was off and all was good.
Bleeding: bleeding was a breeze. I found that the two fittings on the top of the intercooler are exactly R134a/R12 fittings. Bought a kit at Pep-Boys that included R12 to R134 converting connector, then got R134a quick disconnect flling hoses and hooked this to the vacuum. On the fill side, bought a Lisle 24680 Spill-free Funnel kit and the fitting included fit perfectly inside the new tank and provided a tight seal. Filled the funnel as the vacuum pulled the air and fluid out and all was good. I used a "carboy" water tank to catch all the fluid coming out as to not hurt the vacuum pump. This is exactly what the factory is doing.
The tank has an easy to see line for filling and works perfectly allowing expansion in system. No more guessing how much water I have in there. Also, see the pics and you can see that the original one purged and put coolant everywhere. Now, the new tank has enough room to not allow any fluid out when it heats.
Overall very happy with the results. Fitment is perfect and looks factory
Old May 19, 2016 | 04:36 PM
Dr Matt's Avatar
05 CL65
Nice bit of research. I'm sure the reservoir is a decent upgrade, but the newer coils seem to hold up fine so not sure they are worth the swich. I took the idea from another member and added a separate tank for the inter cooler fluid already using a universal wilwood brake fluid tank. It is not much capacity, but a cheap upgrade, allows expansion of the fluid in the system and yes, it does draw it back in as needed without even changing the cap. I think I have a pic of it. If so I'll add it and update this post.
Old May 19, 2016 | 04:52 PM
biker349's Avatar
cl600
thanks for the info. and picks. n ice to know about the upgrades and compatibility issues.
Old May 19, 2016 | 08:05 PM
MooksM275's Avatar
W215 CL65
Agreed as to coils. Would be nice but given current reliability when replaced may not work. However, tank is cool. I just ordered it from Mercedes buttttt......it's on back order. Will update when receive it and work on install. Looks like it may be better to buy the new coolant pipe as well that it attaches to. I'll wait to order the pipe till I see how this tank sits.
Old May 20, 2016 | 04:53 PM
ZephTheChef's Avatar
2004 S600
If they are in fact standalone smart coils triggered by the computer directly, it would not be an easy conversion to say the least (tons of wiring if it's even possible). Possibly requiring other updates including the newer ECU and other sensors/modules that the newer ECU is expecting.
Old Jul 3, 2016 | 11:43 PM
MooksM275's Avatar
W215 CL65
goodies arrived.
I got the goodies. So I found after ordering the tank that two hoses/pipes were needed. The tank goes directly into the new rear cross pipe. I will be fitting next week and will post pics of the install. Here are the parts.
A2792000185-x1 Tank
A2790980891-x1 rear metal line to tank
A2790980283-x1 rear rubber hose
Wish me luck
Old Jul 3, 2016 | 11:58 PM
2004 S600
Interested to see the final install!
Old Jul 4, 2016 | 02:08 AM
AMG-Driver's Avatar
SL65 R230
Zeph and Mooks,Nice.
I put in my Pierburg CWA100 2 weeks ago in my car, and my tuner also ordered the IC reservoir from the M279. The parts were not delivered the day of the install, so I kept the old one, but we bleeded properly with vacuum.
The M279-IC-Reservoir is a good update - I think it should be much more easy to bleed.
Old Jul 4, 2016 | 02:14 AM
2004 S600
I'm not sure that it's relevant now that I have a trunk tank. But since I already added a small reservoir, I would love to swap to one of these if the install looks cleaner/factory.
Old Jul 6, 2016 | 05:44 AM
Welwynnick's Avatar
2006 S600
The other possible upgrade from the W220 (or other recent turbocharged Mercedes) could be the full-height heat exchanger. I saw a picture of one of these and counted 66 rows.
Part No A0995003603
E / SL / CLS-class: A1975000103
It looked to me that bleeding would still be difficult, as the header still didn't have any bleed lines from the intercoolers.
However, it still enables level checking and topping up, which are very important.
I still think the only way to bleed these systems properly is with a vacuum re-filler and a rotary vane vacuum pump.
They get the vacuum down low enough to get literally ALL of the air out, and they cope with the water vapour. Not expensive either.
Nick
Old Jul 7, 2016 | 09:11 PM
MooksM275's Avatar
W215 CL65
Fit great
Old Jul 8, 2016 | 02:10 AM
AMG-Driver's Avatar
SL65 R230
Thanks for the pictures!
Nice clean motor bay and good Work.
Old Jul 8, 2016 | 11:33 AM
Welwynnick's Avatar
2006 S600
"Thanks" doesn't quite cover it! This sounds like a no-brainer.
Nick
Old Jul 12, 2016 | 04:21 AM
AMG-Driver's Avatar
SL65 R230
You mean to use the "thanks button"? When I say thanks, I mean thanks, regardless if I use a button or not. But I have used the button now, for the forum statistics... And also for your Intercooler-Pump Thread, which is obviously one of the alltime Best here on MB.
Old Jul 12, 2016 | 05:31 AM
Welwynnick's Avatar
2006 S600
Sorry, I wasn't referring to your post at all, although I can see that it looked like that. I was referring to my response to Mooks post, which I think I real step forwards for all of us.
Nick
Old Jul 12, 2016 | 07:08 AM
AMG-Driver's Avatar
SL65 R230
Ahh, o.k. - . I will work more on my english language to understand better, because English is not my first language...
Old Jul 16, 2016 | 06:48 PM
MooksM275's Avatar
W215 CL65
Wanted to post follow up:
Level has remained exactly the same as when I filled and bled. No filling has been required.
Intercoolers cool/lukewarm to the touch after cruising on freeway.
All is good for now.
Old Mar 31, 2017 | 02:36 PM
pmercury's Avatar
member
CL
absolute great !
If I wasn't going for a 7 gallon Icebox in the trunk I would have done that too
Old Apr 20, 2017 | 05:04 AM
pmercury's Avatar
member
CL
Part No A0995003603
Nick
for those who want to do that, here:
https://mbworld.org/forums/cl-class-...pgrade-dy.html
Welwynnick's great idea !
Old Apr 20, 2017 | 05:28 PM
Welwynnick's Avatar
2006 S600
I appreciate that, but the idea wasn't from 2016, it was from 2013:
https://mbworld.org/forums/m275-v12-...ml#post5674794
Nick
Old May 5, 2017 | 06:22 AM
pmercury's Avatar
member
CL
Done !
really easy !
one of the best upgrades you can do on your V12TT !
thx for this amazing idea !
Old May 17, 2017 | 01:25 AM
pmercury's Avatar
member
CL
weeks driving now, absolutely perfect upgrade
the level didn't move a MM
Old Jul 10, 2017 | 04:02 AM
pmercury's Avatar
member
CL
did anyone dare the ignition coil upgrade ?
Old Sep 2, 2019 | 10:51 PM
cowboyt's Avatar
Mercedes-Benz S430, S500, S600, and E320 CDI
Thank you for posting this information. I am in process of doing the upgrade for the intercooler circuit. Waiting on the new rubber hose to arrive, then the car will get put back together.
Old Sep 3, 2019 | 01:53 AM
pmercury's Avatar
member
CL
thx
have fun !
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
