S65 AMG misfire
Not sure if there is any benefit to the higher pressures when we run at the single nozzle in front of the throttle body. most of the meth injection is going to be carried to the middle cylinders, i'm sure of it.
Beyond that, droplets half the size have 8x the surface area for heat transfer so it becomes easier to vaporize a larger percentage of the droplets. I kind of went down this rabbit hole when I was having the misfires with the water/meth spraying, so I ended up building that spraybar down the center of my intake manifold using small garden misting nozzles...which have a much smaller droplet size, but require high pressures to get adequate flow. Generally speaking the smaller the nozzle you go with the finer the mist will be, and on a given nozzle the higher pressure you run the finer the mist will be.
It does not help that we have a such an odd coil system.
I really wish there was more clear information available about the coils. It's a very low energy system...I believe I've seen documents referring to the transformer only putting out like 55 watts per side. So they are running 12 coils on something like 5 amps of input current. My Buick runs 6 amps for half that many firings. I can only assume that with such high primary voltage they are concerned more with peak voltage capability as opposed to spark energy/burn duration. So it's more of a capacitive style system which I've never been a fan of. I really would love to re-engineer that, but the cost of doing so even with twin tower coils is still pretty high and would still be stuck with the same coil driver setup. Standalone/aftermarket is really the only option that makes sense and at that point you might have to do something on the fueling side as well and eliminate a lot of the factory features as to not **** off the computer and end up in some sort of limp mode.
I have read that too, 55 watts per bank, in WIS.
I have been reading up on them and am pretty confident I can replace the mosfets and tubes should there be an issue on mine. It would appear getting into them is the hardest part.
It would be rather nice to replace them with the M279 configuration. I wonder if the M279 ecu has a different part number to the M275. It probably does.
Rather interesting!
Does the m275 still use ionic current sensing for knock detection? It has 4 traditional knock sensors so I am not sure.
Rather interesting!
The ecu controls boost by changing the boost control solenoid duty cycle. When it wants less boost it actuates it a lower duty cycle.
If I attached a "bleeding" boost controller to the air line between the IC and the control solenoid and bleed boost manually, the duty cycle adapts to control to 15 psi. If I open up the valve massively, it adapts.
It is actively trying to regulate to 15psi.
All 4 maps sensors are new.
I need to look through the previous service records, but I think they were changed 50,000 miles ago.
When you say re tune, do you mean remap?
Rather interesting!
