M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Eurocharged tune
Old Jul 7, 2017 | 02:21 AM
g60wall's Avatar
2014 E63s
Eurocharged tune
Just wanted to share a pull of my car 2006 S65
0-111mph in mexico
tuned by eurocharged
solid motor mounts by speedriven
billet bov by speedriven
built trans by level ten
Old Aug 12, 2017 | 08:16 PM
RaceHorse's Avatar
CL65
Originally Posted by g60wall
https://youtu.be/Cjak6RB4csQ
0-111mph in mexico
Looks like it pulls hard Do you have any before and after dyno pulls with spraying meth? There are times that I wish I had additional cooling otherswise I try to keep it to short blasts. I think heat soak keeps me from blowing up the car with to many consecutive pulls. For now I'll stick with the trunk tank for events once or twice a year.
Old Aug 17, 2017 | 12:20 PM
g60wall's Avatar
2014 E63s
Meth injection
The methanol/water mix I run now is 15-85. The way the car pulls is astonishing when the meth is blowing. If I'm cruising ambient at 90f, The car IATs will be at 140f. When I floor the accelerator (meth activation is progressive starting at 8psi then going full flow at 22psi. Using a 1000cc/min nozzle) instantly I get 50F drop in IATs. I'm getting my afr gauge installed with dedicated o2 this Monday and will start fine tuning the beast. Meth is an absolute must for this car. The way the car pins you in your seat is pretty wild.
Old Aug 19, 2017 | 04:29 AM
Welwynnick's Avatar
2006 S600
Meth makes that much difference, huh?
Is a meth mix much better than water injection only?
I think this tells us that there's some way to go with the IC system.
Nick
Old Aug 19, 2017 | 10:33 AM
g60wall's Avatar
2014 E63s
Nick
i think, the heat under the hood will never let the intercoolers system run at peak efficiency. I feel like it's a combination, of slightly increased octane and a cool air charge under load. The iats don't rise when meth is blowing, coupled with the eurocharged tune really let's you make all your power every time you hit the gas. With my custom intakes supply more volume to the turbos and then cooling the charge air to sub 100F. Feels like I added substantial power up top
