M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Significant idle fluctuation/stumbling at cold start
Old Sep 23, 2020 | 11:18 PM
sivikvtec's Avatar
2005 SL65 AMG
I started my SL65 up this evening after it sat for around two days. The RPMs started jumping around and the car was rocking. It almost felt like it was going to stall.
I allowed the car to continue to idle and see if it would smooth out, but it did not after a few minutes. I shut the car off, restarted, and everything was fine.
No check engine light.
Does that sound like a misfire? Any ideas?
Old Sep 24, 2020 | 07:35 AM
Renntech6509's Avatar
2014 ML350
I've had the same issue on my S65. I changed my spark plugs and most of the misfires are gone. I just hope I caught it early enough to prevent damage to the coil packs or voltage transformer. I still have a couple of misfires on the driver's side but minimal. I had never gotten a check engine light either. I'd say start checking the ignition system. Also, it would probably be best for you to have a scanner hooked up to her to see which cylinders are having errors. If it's only one side of the engine, you may have an issue with that coil pack.
Old Sep 25, 2020 | 08:43 PM
sivikvtec's Avatar
2005 SL65 AMG
Thanks, drove the car today, all was well.
Ill keep an eye on it and will check fault counters is SDS if it happens again.
Old Sep 26, 2020 | 07:26 AM
2014 ML350
Also check your battery. I've heard before that on these cars a weak battery can also cause some misfires. You said the car sat for 2 days, maybe your battery isn't holding charge like it should.
