M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Cam and lifter bolts
Old Apr 7, 2023 | 08:13 AM
Swamp_Fox's Avatar
2007 SL65
I just found out the cam and lifter bolts are no longer available except for the right side and then only as a kit for a lot of money. The size of the bolts is 7mm x 1mm per inch threads with a length of 85mm and a 8.8 grade. I looked at all my familiar shops for that size bolt as a replacement to no success. I know Porsche says to replace those bolts each time. What do you think about reusing these bolts? Any suggestions on where to get new ones?
