'07 CL600 Radiator replacement
I have coolant leaking from the front of my '07 CL600 and suspect it's the radiator. I figured that I should also replace the all the hoses and radiator mounts while I had the car open. The car has been sitting for over a month and I need to get to it before it gets too hot (I'm in Phoenix, Arizona) I suspect it's straight-forward, but you never know with these cars. Does any one have any pointers or are there any videos showing the process?
I also live in the valley and did the radiator on my 2007 CL600 in my garage a couple months ago. Pretty straightforward. Easier if you have a way to lift the car (I have a set of quickjacks). Don’t remember the exacts as it’s a been a while but if you’re somewhat handy you won’t have an issue.
@tim687 - Your post reminded me that I have WIS installed on my computer. I never used use it and totally forgot about it. After seeing your post, I opened it up and started reading.
@joeshannon095 - Thanks, that's good to know. I'd like to think that I'm handy and managed to replace the coil pack/plugs on one side and voltage transformer with units from v12icpack.com a few months ago.
tim687 (05-31-2023)
