M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
M275 5.5L front sump to rear sump conversion
Old Sep 10, 2024 | 07:48 PM
PrometheusFD3S's Avatar
2006 S65 AMG, 2001 S600, 1995 RX7, 1994 840Ci, 1975 XJ6-C, 1971 Celica Coupe
Hey everybody,
I am looking to buy parts from a local seller, to convert to rear sump, so I can attempt to swap my spare M275 into my C124.
seller is stating that all that is needed is the lower pan, but I think I need more parts.
i
I​​​​​​‘​m assuming I need the upper pan (30) & lower pan (80), as well as what looks to be a windage tray/ splash guard (20) and all gaskets & affiliated hardware.
also, is that an engine oil dipstick???
all my front sump M275 engines have the ****ty oil level sensor, so having a dipstick conversion sounds awesome.
Thank you!
Old Sep 11, 2024 | 07:26 AM
feets's Avatar
2006 C55
You will likely need the upper and lower pan from a Maybach. That's a real W240 chassis, not the tarted up W222.
Rare and spendy, you'll likely need to sell a kidney or two before visiting the dealer.
Old Sep 11, 2024 | 11:25 AM
I believe the 2004+ R230 SL600 & C215 CL600 both had rear sump M275 engines, if I’m not mistaken.
I have a seller locally that’s parting out a rear sump M275, I’m just trying to figure out what parts I need, so I can make sure I get it all at the same time.
Old Sep 12, 2024 | 07:12 AM
feets's Avatar
2006 C55
It's been a while since I was under a SL600 or SL65. If I recall correctly those were mid sump pans.
Maybe someone with one of those cars will chime in.
Old Sep 14, 2024 | 09:34 AM
JohnLane's Avatar
222 S-65
OP if you are going to the effort of fitting a bent-12 to another car the only engine to consider is the six liter with a pair of turbos. Same size package..... much wonderful sickness.
