M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Need Voltage info for V12 coil pack Ignition Trigger and Ignition Change (a/b)
Old Jun 26, 2025 | 05:33 PM
rgdeja's Avatar
SLK55, S65
I am trying to troubleshoot my coil pack and got all the signals fiigured out but need to know two signals
1. Ignition change - is this GND, Vcc (12 or 5V)
2. Ignition Trigger - is this GND, Vcc (12 or 5V)
I can then jerry rig and manually test the coil pack. Jerry used to build and sell testers but he is no longer doing them. I have a spare transformer
Also it would be nice if someone knows the part numbers for the connectors.
Pinout for Transformer and coil pack
N91 - Voltage Transformer:
Pin4/5 - 12V Supply Voltage - Connected to Battery
Pin 7/8 - 23V Aux Voltage
Pin 9/16 - 180V Ignition Voltage
Pin 11/14 - Ground
Pin 12/13 - 12V - Battery Voltage
Chassis - Ground
N92/1 and N92/2
Pin -1 Ignition Trigger CYL-1
Pin -2 Ignition Trigger CYL-2
Pin -3 Ignition Trigger CYL-3
Pin -4 Ignition Trigger CYL-4
Pin -13 Ignition Trigger CYL-5
Pin -12 Ignition Trigger CYL-6
Pin -10 Ignition Offset Cyl 1-6
Pin -11 Ignition Change (circuit a/b)
Pin -8 Ground - Connected to Voltage Transformer
Pin -14 - 23V Aux - Connected to Voltage Transformer
Pin -15 - 12V - Connected to Voltage Transformer (Battery Voltage
Pin -16 - 180V Ignition Voltage - Connected to Voltage Transformer
Pin - 5,6,7 - Ion Current Signals
Old Nov 16, 2025 | 04:30 PM
mrvedit's Avatar
2004 SL600
Did you ever figure out the signal voltages?
Where is the source for that electrical diagram? The diagram is new to me and super educational. It gives me a much better understanding of the ignition "transformer".
Do you happen to know if the pins 4&5 on N91 are on circuit 30 (constant power) or circuit 15 (switched power)?
