MBWorld Featured Car of the Month Contest Featured Mercedes Benz contest submissions, voting, and showcasing.
W212 gearbox issue
Old Jan 21, 2025 | 05:11 PM
w212 E250's Avatar
W212 gearbox issue
When my E class w212 is cold the gearbox act weird and does like a hard one jerk during mid of first gear and only in first gear its almost like a hard shift but I’m already into gear and car is rolling … problem disappears when the car warms up any help please 🙏🏼
Old Jun 7, 2025 | 03:44 AM
hinacarworld's Avatar
Might be worth checking the transmission fluid level and condition first, especially if it hasn’t been serviced in a while. Cold shifts acting up can point to that or an aging valve body.
Old Jun 29, 2025 | 08:27 AM
travisscott's Avatar
bmw
It sounds like the issue could be related to the transmission fluid temperature or an early sign of a valve body issue. Cold weather can cause hard shifts, especially if the fluid is aging or slightly low. You might want to get a diagnostic scan or fluid inspection just to rule things out. Also, while researching similar complaints, I came across some related legal insights onTravis Case Search that might be helpful if any past cases align with technical disputes like this.
Old Jul 17, 2025 | 02:51 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Welcome to the forum!
You would get more and better advice by posting on the correct section of the forum:https://mbworld.org/forums/e-class-w212-109/
Old Nov 26, 2025 | 11:59 PM
Repulsive_War_0's Avatar
Typical 722.9 conductor plate failure on W212. Cold = works, hot = limp mode + stuck in gear → speed sensors on the plate are dying.
Check the gearbox plug for oil inside (wet = plate seal gone). New conductor plate + sleeve ~£250-300 and 2 hrs DIY.
Pull codes first (usually P0717/P0722). Easy fix once you replace it. Good luck!
Old Mar 14, 2026 | 04:42 AM
River-James's Avatar
That’s normal when the car is cold. It should smooth out once it warms up.
