Instrument Panel Removal
Old Mar 8, 2005 | 08:48 AM
EarlStevenson's Avatar
Does anyone have instructions on how to remove the instrument guages on a 1998 C230 to replace a burnt instrument light bulb. Thanks in advance.
Old Mar 8, 2005 | 08:25 PM
Gullwing's Avatar
1987 190E 2.3
Use Mercedes dash hooks, place one on either side of the dash (tight fit) and pull. Best to do one side at a time, pull it out a little bit then go to the other side and pull out a little more... There are no clips that hold it in, like other models it is just a really tight fit.
Old Mar 12, 2005 | 08:34 AM
mbtech75ny's Avatar
cluster
you might want to try pulling from the bottom of the cluster also, in my experience if you slip with the hook you might catch the corner and crack the the plastic cover
