Anyone every pull this code from a chech engine light?
Old Mar 19, 2005 | 07:35 PM
99SlvrC43's Avatar
1998 Silver C43
Just Had the C43 give me a Check Engine Light and I pulled this code
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
What does this exactly mean?
After some searching I found this info out.
Oxygen Sensor part number C5010-88840
Its on the right side and before the three way cat converter. Some one please confirm that. Will replacing it dix the problem or do I need to do something else? (MAF)
Old Apr 10, 2005 | 11:07 AM
larzee58's Avatar
O2 sensor
I had an o2 sensor code which I thought was an easy r&r fix. Ended up having to remove and clean egr tubes and filter along with vacuum lines, cleaned all up and no problem since.
Old Apr 10, 2005 | 03:57 PM
99SlvrC43's Avatar
1998 Silver C43
larzee58 cam you email me a step by step DIY guide on doing what you mentioned?
