P0442 EVAP Small Leak - Where is the beef?
ML 320
Need you help on '99 ML 320 58K miles. CEL came on with P0442 code and no other codes found. Erased it a few times but keep coming on. I've spent a couple of hours here and understood what to check. Thanks for your posts !!!
Gas cap seems very tight, so I guess it could be vac line or purge valve (may be something else - pls tell me). But where is the purge valve and what it looks like? I guess somewhere under the hood but couldn't figure out. Is it easy to replace if needed?
Any comment and advice would be appreciated. Thanks.
The system is setting this code because the system is not leak tight. This could be caused by numerous problems-in this situation it's a better idea to take it to a dealer. They can moniter the tank pressure sensor and see exactly how much it's leaking down. Then they will crimp off hoses/replace components to see exactly where it's leaking. It may not be a component-it might be a seal or a line. In most cases the purge valve will not cause a minor leak-they will cause a major leak. If you want to replace it anyway-look for the throttle linkage under the hood-the plastic bracket that the throttle linkage is on-the purge valve is connected to this with a rubber bushing. The canister shutoff valve is above the spare tire under the car.
ML 320
If that's the case, I think this is not something that I can do as 1-2-3 diy. Ha! When I visited my MB dealer last time for something else (CEL started around that week), I asked about the code and they told me keep eyes on how it goes for a while and if the code keeps coming up, then I will need to replace PV. I think your advice is more reasonable and agree to nail down the leak first....
Anyway, I will try to find PV. Thanks.
P0442/445 P0700 Code
Secondly-I have a P0700 code also. I know this is a generic transmission code but was interested if anyone else had the code and how they corrected it. I am trying to resolve the P0442 on my own. I have an appointment at a local shop known for Mercedes mechanics, I am taking it to them this weekend to have it inspected. But would like to know what I might be looking at first.
Thanks,
