Alignment after control arm bushing change
Can't get a straight answer from the dealership and wanted to ask if there is a good possibility that my front end alignment will be off after the replacement of my control arm bushings.
The dealership is replacing these bushings under warranty but is wanting to charge me for the alignment. Don't see why this would not be covered under the warranty but the SA is stating this is Mercedes "policy" not to cover the alignment.
Also can only the dealer do the alignment ? (the cars an '02 C class)
Thanks in advance..
Thanks in advance..
99 C43 AMG & 2008 Corvette 1LT Z51 LS3
On the W203's the Front Thrust Arm Bushings break quite a bit, if these are the bushings that are being replaced, then a wheel alignment is not needed. If the lower control arm is being replaced, then an alignment should be performed and that should be covered under warranty.
It is better to have your car aligned by the dealer, however any shop should be able to perform a wheel alignment on that car. The one thing about an outside shop doing the alignment is that if your car needs to have the caster or camber adjusted, the outside shop will not be able to adjust that. You would need to get alignment correction bolts from the dealer.
Appreciate the info, Thanks,…
C230
I had to pay also
I had the same warranty work completed during my last visit. I was surprised too when I had to pay for the alignment. I always was told whenever you had any work done to the front suspension components that it was a good idea to have the alignment check. Oh well! The car feels much better with the new bushings. It feels tight again, so I guess the $100 for the alignment was a decent trade (that price was a special the dealer was having. I am sure that is not the regular price).
Regards,
John Cappuccilli
Regards,
John Cappuccilli
1 Post
04 C320 Coupe MT
There was a bulletin recently that said an alignment was not required when replacing the thrust arm bushings because of "close production tolearances"
The funny thing is, if the factory says you don't need it, why would the dealer try to sell it to you? Unless it was slow at the dealer that week?
About the alignment, what was stated about an independant being able to do it is correct. However, they wouldn't have the exact factory specs for your car. The only way to do arrive at specs for your car is to measure the ride height (at the control arms in the front and axle shafts at the rear) and then the specs are calculated, custom for your car. In other words, there is a big chart that that is used to arrive at your specs.
One of the reasons this is done in this manner is that rear ride height has an effect on the front caster. The lower the ride height, the greater the caster. So, in other words you are really getting a custom alignment when you have the dealer do it.
I'm sure there are independants who can align your car just fine, but if you really want it to be exact, have the dealer do it.
Originally Posted by mbbodytech
The funny thing is, if the factory says you don't need it, why would the dealer try to sell it to you? Unless it was slow at the dealer that week.
'04 Porsche GT3, '11 BMW 335d, '12 VW JSW TDI
...About the alignment, what was stated about an independant being able to do it is correct. However, they wouldn't have the exact factory specs for your car. The only way to do arrive at specs for your car is to measure the ride height (at the control arms in the front and axle shafts at the rear) and then the specs are calculated, custom for your car. In other words, there is a big chart that that is used to arrive at your specs.
Originally Posted by ltcjmramos
I'd like to have an outside shop (the one who works on my GT3, and who worked on my 911 Turbo AWD) inspect and align my ML430. Are there not basic specs?
Its been a while since I've aligned an ML55, but the specs should be about:
Front Ride Height: 4.5*
Front Camber: -0.35'
Front Caster: 6*30'
Front Toe: 0.12' or 0.24' Total Toe in
Rear Ride Height: 3.5*
Rear Camber: -0.35'
Rear Caster: -8.5*
Rear Toe: 0.12' or 0.24' Total Toe in
