Do 1990-92 300sl have wiring harness & head gasket probs..
Old May 22, 2005 | 03:28 AM
gocargo's Avatar
Steel Grey 2012 ML350 is wife's
Searching the forum, I read that the 1990-92 300sl models do Not have the dreaded "deteriorating wiring harness". Is this accurate information?
Do all the 104 engines have the head gasket problems around 100,000 miles, even the early r129 300sl?
Thank you..
-Brett
Old May 22, 2005 | 11:28 AM
Kestas's Avatar
95 E320 Cabriolet, 108K
The dreaded engine wiring harness problem is limited to the 93, 94, 95 model years. A good visual inspection of the insulation under the wiring armor would confirm this.
Old May 22, 2005 | 05:51 PM
gocargo's Avatar
Good to know, thanks
-brett
Old May 28, 2005 | 05:25 PM
124-Fan's Avatar
Mercedes Benz
I just replaced the head gasket in my ´92 300 CE-24 a month ago. It was due to an oil leak. It was developing larger and larger oil puddles under it every time I parked the car, which were quite irritating. It has just over 100k miles on the clock and the gasket was simply totally worn out. There were holes in it. I also replaced the crankase oil seal and now it doesn´t leak a drop. -No wiring harness woes in this engine, though.
