Oil leak on S600
2001 CL600
Oil leak on S600
My 1995 S600 has an oil leak. The oil is leaking from an oval shaped plate which is located near the bottom of the oil filter housing. The plate has a bolt through it which is located in the center of the plate. I am sure there is some type of rubber gasket or grommet below this plate that needs replacing. Does anyone know the name of this part or a part number? It only leaks while the engine is running.
