Please help: Troubleshooting Aux Fan Short R129
Old Jun 15, 2005 | 11:24 AM
R1990's Avatar
Hello everyone. I posted this question in the R129 forum but not getting any feedback whatsoever there so I thought I'd give the tech forum a shot.
I've got a 1990 300SL-24 with a short circuit problem in the auxilliary fan circuitry. Basically, everytime the aux fans would come on, either by A/C or water temp, the aux fan fuse will blow immediately. I checked the wiring on both fans and nothing seems to be out of place or grounding anywhere. All insulation seems fine. Im a bit challenged when it come to electrical issues so I would appreciate if someone could help me out. Does anyone have a wiring diagram for this application? I was thinking as a last resort, just to re-wire the aux fan system but I would need a wiring schematic to do so. I think that a 1990 -up 300CE or 300E would be similar since we share the same engine? If anyone has any advice or suggestion, please post. Thanks in advance
Old Jun 15, 2005 | 11:50 AM
Moneypit SEL's Avatar
Before you do all that, find out if it's the fan itself that is causing the problem. Disconnect the aux. fan wiring connector, then jump the fan switch on the A/C receiver/dryer. If the fuse does not blow, then the fan is at fault.
Old Jun 15, 2005 | 01:31 PM
R1990's Avatar
Sound logical. I will try that later when I get home. I also learned that it might be the aux fan resistor that's at fault, probably grounded somewhere. I will post an update later on my findings. Thanks!
