S-500, tire feathering
Old Jun 19, 2005 | 03:13 PM
tj mummery's Avatar
My mother-in-law has an 2003 S500 4-matic and since new she has complained about the car pulling and vibration in the wheel. When she took it in, the tech said it was fine and balanced the wheels. At around 20000 kms she noticed the outer edge of the front tires were badly worn. The dealership rotated the tires and gave the reason for the wearing was her driving aggressively and the weight of the car. After about 7000 more kms she brought the problem to my attention. I looked at the tires and drove the car. It pulled and there was a shimmying in the wheel. I felt it was an alignment problem. I spoke with the service manager at dealer 1 and after much debate he agreed to align the car and replace two tires free of charge. He did tell us that we can expect to replace tires every 20000 kms and have alignment done every 2 months. I couldn't believe my ears. We wanted to switch from the contenental tires to the michaline MXV4 so we paid the difference and told them to replace all four tires. After the work the car seemed to handle better. The car was taken to dealer 2 for routine maintenance after 4000 kms. This dealer said the car is pulling, the front tires are feathered and we should take it back to dealer 1 for alignment. We went to dealer 1 and they said the car is fine and they would not do anything. So we went back to dealer 2 and they agreed to do the alignment. They rotated the tires, made alignment adjustments and told us to come back after 2000 kms. After 2000 kms we brought the car back and the front tires were badly feathered. Now we have four brand new tires badly featherd and no answers. The service manager showed the tire manager and he said right away the car needs alignment, the service manager said alignment has been done already. This dealer has now agreed to do alignment again and also replace two tires which they claim michaline is covering under warrenty. That still leaves us with two badly damaged tires we paid for 7000 kms ago and no answers as to what is wrong with the car. They won't replace the back tires which if they hadn't rotated would still be fine and they said if this alignment doesn't solve the problem then there is nothing else they can do for us. This dealer also blames aggressive driving and the weight of the car as the reason for the tire damage. They also say that alignment needs to be done every two months and tires need to be replaced every 20000 kms. I think they're crazy if they expect me to belive this. My mother in law is not an aggressive driver and the dealers claim that no other s500's are comming in with this problem. I have contacted head office and they leave it in the hands of the service managers. What is wrong with this car?
Old Jul 2, 2005 | 10:09 PM
Tishers's Avatar
'06 C350 4MATIC
Alignment
The wheels feel loose? Did they check the ball joints and tie rods? Loose ball joints or tie rods can make the tire feel loose when on a lift.
Is it scalloping? In other words, like scooped wearing on the tire or is it universally worn out?
Aggressive driving can wear down the front tires quicker (taking turns a a high speed). So can too much toe-in on the front tires or a misalignment or something wrong with the ball joints or tie rods.
Old Jul 5, 2005 | 09:51 PM
Mercedes Tuner's Avatar
99 C43 AMG & 2008 Corvette 1LT Z51 LS3
All 4 Matic's wear the front outer edges of the tires severly. This is due to the 4 matic system. Since all 4 wheels are powering the car, during cornering the tires fight each other and cause the excessive wear. I've seen the same problem on many of them. There really is no fix for it, but somethings can be done which will help a little.
When the alignment is done, make sure the front toe is set to the minimum amount, or most toe'd out as possible and be within specifications. The next is to have alignment correction bolts installed to increase the amount of negative camber that the front wheels have. By increasing the amount of negative camber it will make the tires ride on the inner edges more and will take load off the outer edge of the tires, this in turn will make the tires wear more evenly.
Other then that, the only thing that can be done is to rotate the tires every few thousand miles.
Old Jul 6, 2005 | 12:33 PM
mleskovar's Avatar
'17 Jaguar XF
Is this the same for all four wheel drive systems?
Old Jul 6, 2005 | 07:10 PM
If its full time AWD then yes, they are very hard on front tires. Some companies have their AWD systems biased more to front or rear, or like Subaru that's a Different AWD that sends either power to front or rear, not both at the same time. Those are not as harsh on the front tires. Usually cars that have AWD are harder on tires then trucks, due to cars using a much lower profile tire. Due to a lower profile, the tire does not have the flexability in the sidewall, so any problems show up much easier and sooner.
Another thing that could be done is to add a few PSI of tire pressure to the front tires to try and even things out.
