Contour seat doesn't work.
My driver's side contour seat does not work. Does anyone know a quick fix or how to determine what's wrong with it?
2015 E250D
first check the pump. turn car to ign on. Don't start it. Go to the trunk and listen for a pump on the left hand side. If it's on, then you have power. You then should check for a air leak in the lines. The air connector under the seat may have come off or is kinked. Check under the drivers seat for this.
