DAS question (W203 C55 - Optional Equipment Section)
Old Jul 21, 2005 | 10:51 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Hopefully a tech or the moderator can provide insight into this...
When performing the version coding for the integrated telephone, the DAS system takes you through the optional equipment section where you need to select that the telephone is 'present'. While in that screen, two options were reported as 'not coded' - Navigation and Memory. DAS will not continue with these options as 'not coded' and must be selected to either 'present' or 'not present'.
Knowing the car does not have NAV - I coded to 'not present'. However, I could not find any description as to what 'Memory' refers to. I coded to 'not present' to continue.
Any idea what this 'Memory' option is - and should I change the select to 'Present'.
Thanks!
Old Jul 21, 2005 | 11:50 AM
SUNILP's Avatar
2015 E250D
keep memory to not present as well
