BAS light w210 e240 1999
w210 e240
Error codes c1202
c1203
c1332
Can anyone tell me the error codes for these?
Tech tells me I need a new brake booster because the BAS read switch must be faulty. Dash (BAS) light tells me I have a fault. Have changed the brake switch and error still exists.
Can you order the BAS read switch or the BAS travel sensor which is connected to the brake booster seperatly.
Error codes c1202
c1203
c1332
Soleniod valve BAS
Morning, this has just happened to me today code C1332, brake light switch changed, no change, now in limp mode, so where is the N48 BAS CONTROL MODULE SOLENOID VALVE,
By the way my last car an SLK fixed with imfo from this site (malcom) super site
Mercedez Benz c240 2002, color=Silver, Gasoline
Hello All,
I am getting this error c1202 Break Assist System Bas Release switch ESP and ABC and the car slows down and stays at third or first gear. After I turn off the engine and on then the ABS light is off and the car runs fine. This happens occasionally.
C1020. No idea what sensor is bad etc..
C240 2002
C240 2002
