removal of steering wheel w210
i need to know the torx size to removal the airbig and the size of the nut to removal the steering wheel for 2002 e 320, i am upgrading to a brabus steering wheel. thanks.
If memory serves me correctly it is a 30 Torx for the airbag and a 10mm hex bit for the wheel. You'll need a long breaker bar for the wheel as well as a torque wrench to reinstall. You should probably have an assistant hold the wheel while you use the breaker bar and hex bit to get the wheel off. YOu don't want to break your steering lock. You don't have to disconnect your battery, but if turn the ignition past position 0 while the airbag is off, you'll trigger the SRS light. (This light cannot be reset by disconnecting the battery) So, I would disconnect the battery before hand, just in case. Good luck!
