2000 CLK320 Engine and A/C query (facelift model)
Old Jul 27, 2002 | 05:15 AM
barflux's Avatar
CLK 320 Avantgarde
Smile 2000 CLK320 Engine and A/C query (facelift model)
have a 2000 CLK 320, with a problem with the engine:
The engine sometimes twitches in Park, Drive or Neutral (revs are around the 500 mark). I really want to sort that out but, dealer said needle in haystack, as no faults are showing on Star Diagnostics. I changed the Air Filter, no difference. Why is it shaking slightly, there are no problem if the car is creeping or moving.
also
I have a strange "gas seeping (hissing) noise out of the middle vents" occurring constantly when I have my A/C on, if I press EC then the noise goes away. So obviously it sound like A/C gas or something. My A/C seems to work fine, except this noise has now started.
In addition to the above
It has done 23000 miles, and has only started twitching since November last year where I had done 19,000 miles. They had done a B service in December, but could not find the fault. What could trigger this problem? In motion the car is so smooth. Star Diagnostics found nothing, except something to do with my emissions control, but it was not serious (burns a little more petrol than normal but I still get 25mpg in city and freeway driving), as they don't have strict laws in UK. But no other checks, they said they will keep the car and try and look for it. I will try again. I did the air filter as it is easy, and an obvious start, the old one which was in december was ok, but i still replaced it. Could MAS, oil service, gunk in the engine, spark plug, counterbalance shaft? Not sure if it is a comman problem. People with the CLK430 are also having a similar problem. But thats a different engine.
About the A/c I had damaged the condensor, which was replaced and the a/c was said to have been recharged. Now the a/c is bloody freezing, which I guess is good, but the noise is constant coming and going every 5 seconds for the entire journey. Is there a leak somewhere?
Nick
