HELP! Broke tubing while changing MAF.
here's some images, hopefully i can explain.
here's the back of the engine, you can see the MAF sensor. notice the tubing that comes in from the right goes along the top. It then goes under behind the MAF, comes back out the other side, loops over the MAF cable connector and then goes into the engine:
now if you look closer, to where that tube goes into the engine, you'll see that i've broken it:
now first of all, does anyone know what this tube is!? i'm really worried it might be fuel-related.
secondly, am i going to be safe duct taping it, or hot glueing it back together temporarily -- to make the 10 miles or so to the dealer?
and thirdly, is this a tube i can replace myself if i get the correct part from the dealer? the only reason i ask is because i know if i go to the dealer to have them fix it my service representative guy is going to be condescending and yell at me for having tried to fix a Mercedes myself. i know i f-ed up, and i've been f-ing depressed all day about it, but it's not because i wasn't taking care. it's not like i banged it about with a wrench or something. it was the slightest tap of my fingers.
please if anyone can help, i'd really appreciate it. my car's completely grounded til i can figure out what to do.
thanks!!
-kev
Last edited by purplegrog; Jan 22, 2006 at 08:51 PM. Reason: adding additional info
it's a 2001 c240, sorry, i really should have mentioned that shouldn't i...
thanks again, i do appreciate any input anyone may have on any part of this!
-kev
Just watchout, its the tube that supplies you vacuum to the brake booster. Without it attached, you will basically have manual brakes and it will be hard as hell to stop the car.
any advice on how to make sure i connect the replacement correctly? in terms of making sure it's a good seal, etc. from what it sounds like it wouldn't be too pleasant if it came apart while i was driving...!
thanks again, guys.
-kev
thanks again, guys.
-kev
Anyway, I'm all fixed up finally (almost two weeks later!). My MAF replacement turned out to be a lot more expensive than anticipated. Thanks again for the help guys!
-Kev
