ABC help on 00 CL500
Old Jan 23, 2006 | 09:22 PM
ScottCLS55's Avatar
Lexus
Ok,
I'm going to an auction tommorrow and may buy a 00 CL500 with 49k. It has the abc light on. THe car rides fine, I test drove it today. The mechanic that works at the auction said he pulled the code and it said bad abc pump.
I dont see how this is possible, isnt the abc driven by the power steering pump?? The power steering worked fine on the car and the abc fluid res. was full, the filter looked alittle dirty.
My question is what is likely the problem?? And how much??
Does a flush and filter change ever fix the problem??
Also a battery was just replaced, any chance the light needs to be reset??
Thanks for your help in advance,
Scott
Old Jan 25, 2006 | 09:18 PM
ScottCLS55's Avatar
Lexus
I bought this CL. The red abc light comes on when started, the level is high no dropped struts. There is a leak around the pump and resevior. The strut is not leaking but the pump or hoses were and the fluid was slung all over the underside of the car. The leak is coming somewhere around the PS pump, where all of the hoses meet. The shock is not leaking and the pressure valve is not leaking (valve under the passenger floor)either. Maybe the light is on because of the low fluid level. Its not very low but about 1 inch below the cold mark. Its not a pouring leak either. The red light will go off in about 5 minutes after driving.
Do any Techs run into this? Do the hoses need new brass washers?? Do I need new pump? Hoses?
Thanks,
Scott
Old Jan 30, 2006 | 10:21 PM
ScottCLS55's Avatar
Lexus
Update, Pump was leaking at the front seal, going to replace the pump.
Does anyone know the abc fluid capacity?
Old Jan 31, 2006 | 10:44 AM
purplegrog's Avatar
2012 C250
this is OT, but how much did you pay for the car at auction? was it an open to the public auction, or closed dealer type auction?
