Pipe between fuel distributor and lower manifold section
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Does anyone know how to remove the wierd clip holding the rubber sleeve to the lower half of the fuel distributor ? The clip appears to be some kind of rachet mechanism. Theres not enough room to get clippers or anything in.
PS removing the manifold is not an option due to the state of some bolt heads (They are supposed to be Hex although internally they are are now round ish)
Charlotte
Charlotte
Clip off Very Rusty
Ok folks the clip is now off just needed a lot of releasing spray and some gentle persuasion from the non MB tool (the most important in the box)
Now How do I seperate the rubber sleeve from the manifold ? Just pull or is there some other non MB Tool ?
Charlotte
Charlotte
It always helps if you describe whether the car you're asking about is a Mercedes and then which model it is and then what engine it has.
Description Mercedes Benz 500 SE Uk Spec 5.0i engine V8
Sorry
It's an 1985 (manufactured 1984) Mercedes Benz 500SE UK spec 5.0i V8 Engine with a Bosch Fuel injection system possibly K Jetronic or CIS
Charlotte
Charlotte
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
I am still having problems removing the air guide housing to my 85 500SE (uk spec) it appears that the lower portion is a rubber type compound so don't want just use excessive force but would love suggestions how to remove it.
Charlotte
Charlotte
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
The fuel distributor is seperated just need to replace it as it has a large hole in it.
Don't suppose anyone has one MB are quoting large sums of money.
it's part number is 115 140 0018
Charlotte
Charlotte
