1995 e320 running hot
Old Feb 19, 2006 | 03:53 PM
Jamman's Avatar
1995 e320 Mercedes Wagon
Question 1995 e320 running hot
Hi, looking for some help. I have checked the oil and the coolant and they are at normal levels. The temp gauge rises to 120 very quickly within driving of 10 miles or between 5-10 minutes. I recently replaced the air blower around Christmas time cost plus labor $750. Do you think it could be a sticky thermostat or should I have the radiator flushed and replace the thermostat too ? What do ya'll think ? Any one know of approximate costs ?
Jamman
Old Feb 20, 2006 | 02:39 PM
Hightower's Avatar
remove the thermostat when cold and drop it into warm water, you should see it move the valve, sounds more like the water pump or the radiaor though
Old Feb 21, 2006 | 01:13 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
Welcome, fellow Livonian! Does the problem appear only on the freeway, in stop-and-go, or both? Do you know if the cooling fan comes on when the car is warmed and idling?
Old Feb 21, 2006 | 07:17 PM
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
Has feeling the surface of the radiator been tried? If the radiator has blocked or restricted passages, then that area will be cooler than the rest.
With the engine cool, remove the radiator cap, then start the engine. It is possible to observe the effect of flow, by examining the fluid at the cap. If no flow, from an obstruction or bad pump, then that may be seen.
Old Feb 23, 2006 | 02:27 PM
Jamman's Avatar
Talking
The fan is ok. Radiator is ok. I removed the old thermostat and replaced it. I put the old one in hot water to see if the mechanism would move it didn't. Thanks for the replies it helps sharing info.
Jamman
Old Feb 23, 2006 | 02:31 PM
Jamman's Avatar
Ole', fellow Livonian I replaced the thermostat and drove it around the town yesterday for 45 minutes on freeway and off and stop and go. The thermostat stayed around 80 to 90 and didn't go any higher. Send me a message and we'll get together and compare notes. Thanks for the reply
Jamman
