Best place to get MAF sensor for C220?
1994 C220
I need a new MAF sensor, the part # is 0 280 217 100 and cheapest I can find it for is $307. Are these available anywere for cheaper?
2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
you could try www.worldpac.com. A decent price at a dealer would be $492, so $307 isn't so bad. I'd say if you get down to about 250 - 260, you're doing well.
Replacement MAF
I used a VW Jetta MAF in my 98 C230. Works fine. I took the interior part with the connector apart from the casing and put it in my old casing (you just need tamper proof torx). Try one from the scrap yard before taking it apart. If it works, you pay 100$ instead of 300$.
Good luck.
Good luck.
