Close assist
Close assist
Im working on an '03 S430 with close assist doors which arent workng on the front doors, I thought about replacing the entire door lock actuator but when checking the actual values on the DAS the micro switch is operating normally. My second guess is the PSE pump/control unit malfunctioning. Has anyone dealt with this problem before and have any advice?
Most likely the PSE pump. It may also have an air leak in the system. Test fit a pump, if that doesn't work I'd start looking for air leaks in the system.
