Oil Light at 3500 rpm?
Old Aug 4, 2006 | 04:22 PM
kraut2's Avatar
2007 SLK 280, 2012 C350, 2012 C63 P31
Hola - Have a 2000 C230k 73k miles - my oil light is coming on around 3200-3500 rpm's (80-90 mph). If I slow down to 70 mph, it goes off. Similarly, if I put 'er in neutral, it goes off. Oil level is fine. Also seems slight grade makes it happen.
Could it be a faulty sensor? Does the light also indicate low pressure or just level? Could the oil cap be losing pressure?
Please advise - thanks
Old Aug 4, 2006 | 04:48 PM
JDM's Avatar
JDM
2011 C300
I posted on your other thread.
It's not your oil cap. It could very well be your oil pump, or clogged oil passages..get it checked.
Old Aug 4, 2006 | 06:21 PM
glassJAw's Avatar
'01 E55
For staters, when was the last time you had your oil & filter changed??
Old Aug 5, 2006 | 10:24 AM
shandy2550's Avatar
1995 c220 auto
How do you check your oil level ?,if you use the dash readout it may be that the sensor is faulty and you are very low on oil, have the level checked using a dipstick.
Geo.
