420 SEL Air Condition Help
Old Sep 5, 2002 | 07:47 PM
djohnson's Avatar
86 420SEL Air Condition always on and off in hot days. Seemed need accelerating certain time can kick on, then it kept off and reduce spped can kick on again, I know there is switch to compare the compressor and motor, I doubt if the belt loose cause the problem, or other reason? I don't know how to tighten the belt, It seems not accessible and no adjust screw for compressor belt. And I wonder if I can by-pass the switch just simply turn the a/c always on,because it's really hot here, don't need adjust. Please help.
D.J.
Old Sep 7, 2002 | 02:14 AM
phungpho's Avatar
2000 E430 Desert Silver
djohnson,
I am not sure if your car has a thermosthat. If it does then may be you can by pass it. I guess the switch should be OK. Good luck.
