Coolant drain plug for the 2001 C v6?
Old Nov 6, 2006 | 10:04 PM
otmal's Avatar
Is there such a drain plug for this W203 V6 engine?
(for the coolant change)
I couldn't find it given the space around both sides of the engine are
really tight. Even if there was one, I don't think I can reach it.
Old Nov 7, 2006 | 06:24 AM
SUNILP's Avatar
2015 E250D
It's there. Red in color usually. Drivers side. You'll have to remove the front plastic belly pan.
Old Nov 7, 2006 | 02:41 PM
otmal's Avatar
Is it below or above the exhaust pipes on the driver side?
Old Nov 7, 2006 | 03:45 PM
lkchris's Avatar
'10 CL550, '12 GL550
You really ought to have the service manual for your car.
Coolant replacement is a quite complicated process requiring battery disconnection and an expensive special tool.
I've done plenty coolant changes, but after reading the M112 procedure had the dealer do it.
Old Nov 9, 2006 | 04:26 PM
mleskovar's Avatar
'17 Jaguar XF
[QUOTE=lkchris;1829291]Coolant replacement is a quite complicated process requiring battery disconnection and an expensive special tool.QUOTE]
Special tool for what? Battery disconnect why? I changed my coolant, no problem, nothing special.
Old Nov 9, 2006 | 05:32 PM
SUNILP's Avatar
2015 E250D
I'm not sure what you are talking about but I have done plenty of 112 and 113 coolant changes. No battery disconnection is required and no special tools. You just have to make sure you bleed the air out.
