what is a MOT valve? and where is it on my c32
Old Dec 28, 2006 | 08:59 AM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
hi all,
I have a tapping noise coming from the rear of my engine on the passenger side. the car sounds like a diesel truck. my car is a us model '02 c32 and the noise is not coming from the engine (lifters) or from the purge valve. i am trying to figure out what the noise is and it's driving me friggin nuts. i have searched other forums and noticed that a few others at another forum mentioned the "MOT valve" may be bad. i have no idea what this MOT valve is or where it is located. thank you
Old Dec 30, 2006 | 04:47 PM
Mercedes Tuner's Avatar
99 C43 AMG & 2008 Corvette 1LT Z51 LS3
The MOT Valve is the Purge Valve, it is located on the Drivers Side Inner Fender area in front of the upper spring perch. If you are having a noise from the passengers side, engine rear, it may be a lifter issue. There are no other item which I know of in that area that may cause a tapping sound.
Old Dec 30, 2006 | 05:15 PM
itsmeek's Avatar
doh..lifters it is. time to take za engine apart. maybe next weekend.
thanks
meek
Old Jan 12, 2007 | 07:26 PM
MBTECH2003's Avatar
2000 ML 320, 2003 CBR600F4i, 99 Eclipse GSX
Do you have experience and tools to replace the rocker arms, lifters and cams? There are many special tools need to perform this job and not risk severe engine damage.
Old Jan 12, 2007 | 07:29 PM
itsmeek's Avatar
hehe, yessir i do. i just had never heard of it being called a MOT valve.
Old Feb 5, 2007 | 04:06 PM
itsmeek's Avatar
problem was remedied..it was a bad plug in cylinder #6..
Old Feb 5, 2007 | 08:37 PM
Ok, so you had an engine misfire? No Check Engine Light or Codes?
