Diagnostic interface
Old Jan 19, 2007 | 06:03 PM
Max77's Avatar
C 270 cdi
Hi
I have purchased this diangostic interface for my laptop
http://cgi.ebay.com/Mercedes-Benz-Sc...QQcmdZViewItem
but when connect OBD cable to my W203 the laptop doesn't connect.
Can you help me?
Old Jan 19, 2007 | 11:38 PM
tom0329's Avatar
96 S420 03 CLK 500
How is it working did you get the software with it?
Old Jan 20, 2007 | 05:42 AM
Max77's Avatar
C 270 cdi
I use Carsoft V7.4 MB, when I try to connect shown this messages:
Comunication under costrution....
Module is not build in, or does not respond
Old Jan 20, 2007 | 11:05 AM
tom0329's Avatar
96 S420 03 CLK 500
I've been reading up on this site.
http://www.obd2allinone.com/sc/toplevel.asp?cat=0
Old Jan 20, 2007 | 05:11 PM
David in OZ's Avatar
1978 280CE & 1997 SLK230 Kompressor
I have the same Carsoft 7.4 Interface............ works well with my 1997 SLK 230K
Are you using a 38pin diagnostic connector or the 16pin OBD11 connector?
Not familiar with your MB model....? year.....this interface is not compatible with CAN-BUS
Cheers
David
Old Jan 22, 2007 | 02:21 PM
Max77's Avatar
C 270 cdi
I have a 08/2001 C class and use OBD2 16 PIN connector.
Are you sure that it is not compatible with Can Bus?
Old Jan 23, 2007 | 01:49 AM
Most sellers state 'compatible with original interface'......which I read to mean the 38pin interface before OBD11
An OBD11 cable was supplied with my unit, but I understand it only works with pre CAN-BUS MB's
Link to one seller who states 'Not compatible with CAN-BUS'
http://ucables.com/ref/MB-CARSOFT
Cheers
David
Old Jan 23, 2007 | 12:21 PM
Max77's Avatar
C 270 cdi
Where can I purchase an interface CAN BUS compatible?
