ethanol operation
cheaper than a benz...
ethanol operation
i have seen a few cases where some people have run ethanol in there car, and not completly using the whole tank ie) fill the car up full with ethanol, then halfway through the tank the car gets filled with gasoline..
so whats the problem you say then?
car does not start
if you have this issue with your car...(seen a few c classes with this problem)
the fix is a flash of the ME, and problem is fixed
this is a new problem that has a bulletin that came out just a week or 2 ago...
im the phantom mercedes tech......i dont say where i work or where i am located....
car does not start
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Yes to E-63 AMG! No to E-85 & C2H5OH
there are lots of reports saying ethanol and E85 are a total waste of resources and one of these fancy green ideas concorted up by David Sue Sue Gee, politicians and corn farmers. It takes much more energy to grow and harvest the corn and make alcohol then buy the black stuff from the Middle East and Alberta.
MB sucks oil
car does not start
car does not start
i agree mb doesnt advertise the e85 ethanol as much as they should
on the sucking of oil out...yes i admit to doing that...but on amg cars..I DRAIN THE OIL FROM THE PAN. the e55 has 2 plugs and a few others i pull both plugs and put new copper seals on....i turn it up a notch on AMG cars...no offense to non amg owners...but thats what i do...
05 ML350, 85 300D
Actually the car never has to be run on ethanol, the winter blend we have here in Ohio, tricks the car into thinking it is on ethanol.the car increases its factor to around 1.32 or so, cold hits- car floods its self. And BTW, phathom tech- all the flash did was make it worse (at least in this part of the country), you had to do it to reset the control module back to a 1.0 factor, until 01/07 sds software- now you can reset it with that.
Trivia....Although not advertised as such- every benz with a 27X engine is dual fuel, thats what the 2 means..1 is gasoline, 6 is diesel...
well i hadnt personally flash the car for the ethanol gas start problem...another guy at work did it...so it'll be his comeback...not mine if it malfunctions again..
the gasoline problem may be regional...a couple of years ago the southeast had a MAJOR problem from shell gas having too much sulpher..destroying the fuel level sensor indicator in the tank....causing it to register the incorrect amount..a few times it was a programming issue..and the rest were the sending units in the tank.
im not here to fight with another tech or prove im better than anyone....usually the people that boast the most know the least....and ill be honest i dont know everything....if i have questions ill ask...or look it up
yes ill admit..i give amg cars better attention....our oil suckers at work here arent very good...so most of the time its oil pan plug....
i honestly dont care for the oil sucking out....you are not getting ALL the used oil out.....
so yes i will agree....its a lousy idea to suck the oil out
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
05 ML350, 85 300D
Wasn't trying to fight, or prove anything, fixbenz, sorry if it came across like that.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Our fuel is labled 10% Ethanol. I have never experienced any issues other than a very slight decrease in mileage with my E320 or my ML500. The info that I have received from my dealer is that it will present no problem.
sosh im talking about people that run straight e85 in a tank not the 10% additive in regular gas
they fill up the car with e85 and not use the entire tank....ie not going below the half tank or running on to the reserve fuel light.
they dont use all the e85 in the tank, and it screws with the cars programming
and ill be honest...some of the flashing and programming...mercedes doesnt tell us EVERYTHING...that this software flash will fix or remedy
ive read in other forums of people speculating..what these flashes do
As sosh said, mileage drops with ethanol blends. A gallon of pure ethanol has only 66% the energy content of a gallon of gasoline. Perhaps of more interest to some, the net carbon emissions from running E10, a 10% ethanol blend, are only 3-4% lower than from running pure gasoline.
Any relatively modern car is safe with E10, a 10% ethanol blend, but not with higher blends unless it's dual-fuel. The cutoff date before which E10 is not a good idea is only important to those who read the vintage section. I don't know what it is, but it's quite a while ago. As we hit mandatory biomass content for gasoline in our various jursidictions, the owners of these old cars should go through their fuel systems upgrading rubber parts.
