removing spark plugs wires from spark plugs
Wrong! No amount of moderate pulling on the wire cap on the plugs would remove them. On closer inspection, I see a metal clip at the base of the cap that surrounds it. It looks like its in two parts, linked together.
I've never seen anything like this on other cars - just pull the wire cap off and access the plugs. But not MBZ!
What gives? Do I need a special tool to remove the clip and then the cap?
Are the plugs torqued? If so, what's shold they be torqued to?
New to the Mercedes world!
know how many I damaged when I use to work on them. What I used to
use is side cutter pliers and pull where the two halves of the heat shield meet.
See http://www.startekinfo.de/etools/con...3 589 00 37 00
