w124 fault code reader
Old Apr 13, 2007 | 01:09 PM
BenzBro's Avatar
1990 300CE, 1984 190e 2.3 (sold)
I have a 1990 300CE-24. When looking at the DIY fault code reader instructions i found on MBworld, i see it says insert black plug into pin 1, red into 16, and the third color into whatever you want to check.
My problem: My 16 pin is empty!
Any ideas? I DO have contacts in #'s: 1,3,6,7,8,14.
All other numbers are empty.
Seeing how #16 is supposidly power, i tried connecting it to the battery, then checking 8 and 14, but there were no flashes from the LED. By the way, what does 3,6,7 check?
Thanks,
Michael
Reference thread:
https://mbworld.org/forums/showthrea...ht=code+reader
Old Apr 16, 2007 | 09:48 AM
dbrace's Avatar
The link to the old post does not bring up
the DIY Fault code reader
I would like to build one
Does anyone have the details?
Old Apr 25, 2007 | 01:13 PM
BenzBro's Avatar
http://www.mercedesshop.com/shopforu...d.php?t=107630
Old Apr 25, 2007 | 01:19 PM
BenzBro's Avatar
Fyi
For any others with my problem.
I found on that link i just posted that there was another link to using a code reader. Under the connection part of it, it says the 16 pin is empty in some models and to just use the + battery for power instead.
http://www.geocities.com/MotorCity/D.../cs1000_mb.pdf
Old Apr 27, 2007 | 10:14 PM
BenzBro's Avatar
Do any of the tech's here or even other members have a good link, or list they could post for fault codes in the w124? I'm getting conflicting information for the fault codes i have.
